to: Гоблин
(22.04.2012 в 12:21)
| | Проблему копирования русского текста через буфер решил вопрос закрываю.
Option Compare Database
Option Explicit
'am 030305_14:59:26 --begin-- **************
'так как проблема при копировании в буфер тектста
'в юникода при латинской раскладке
Private Declare Function GetKeyboardLayoutName Lib "user32" _
Alias "GetKeyboardLayoutNameA" (ByVal pwszKLID As String) As Long
Private Declare Function LoadKeyboardLayout Lib "user32" _
Alias "LoadKeyboardLayoutA" (ByVal HKL As String, _
ByVal flags As Long) As Long
Private Const KL_NAMELENGTH = 9
'am 030305_14:59:26 --end-- **************
Declare Function OpenClipboard Lib "user32" (ByVal hwnd As Long) As Long
Declare Function CloseClipboard Lib "user32" () As Long
Declare Function GetClipboardData Lib "user32" (ByVal wFormat As Long) As Long
Declare Function GlobalAlloc Lib "kernel32" _
(ByVal wFlags&, ByVal dwBytes As Long) As Long
Declare Function GlobalLock Lib "kernel32" (ByVal hMem As Long) As Long
Declare Function GlobalUnlock Lib "kernel32" (ByVal hMem As Long) As Long
Declare Function GlobalSize Lib "kernel32" (ByVal hMem As Long) As Long
Declare Function lstrcpy Lib "kernel32" (ByVal lpString1 As Any, _
ByVal lpString2 As Any) As Long
Declare Function lstrcpy2 Lib "kernel32" Alias "lstrcpy" _
(ByVal lpString1 As Any, ByRef lpString2 As Byte) As Long
Declare Function EmptyClipboard Lib "user32" () As Long
Declare Function SetClipboardData Lib "user32" (ByVal wFormat As Long, _
Public Const GHND = &H42
Public Const MAXSIZE = 4096
Public Const CF_TEXT = 1
Function ClipBoard_GetData() As String
Dim hClipMemory As Long
Dim lpClipMemory As Long
Dim MyString As String
Dim RetVal As Long
Dim lSize As Long
If OpenClipboard(0&) = 0 Then
MsgBox "Cannot open Clipboard. Another app. may have it open"
Exit Function
' Obtain the handle to the global memory
' block that is referencing the text.
hClipMemory = GetClipboardData(CF_TEXT)
If hClipMemory = 0 Then
MsgBox "Could not allocate memory"
GoTo OutOfHere
'am 040610 - размер нужно узнать
lSize = GlobalSize(hClipMemory)
' Lock Clipboard memory so we can reference
' the actual data string.
lpClipMemory = GlobalLock(hClipMemory)
If lpClipMemory <> 0 Then
MyString = Space$(lSize)
RetVal = lstrcpy(MyString, lpClipMemory)
RetVal = GlobalUnlock(hClipMemory)
' Peel off the null terminating character.
MyString = mID(MyString, 1, InStr(1, MyString, Chr$(0), 0) - 1)
MsgBox "Could not lock memory to copy string from."
OutOfHere:
RetVal = CloseClipboard()
ClipBoard_GetData = MyString
Function ClipBoard_SetData(MyString As String)
Dim hGlobalMemory As Long, lpGlobalMemory As Long
Dim hClipMemory As Long, x As Long
' Allocate movable global memory.
hGlobalMemory = GlobalAlloc(GHND, Len(MyString) + 1)
' Lock the block to get a far pointer
' to this memory.
lpGlobalMemory = GlobalLock(hGlobalMemory)
' Copy the string to this global memory.
lpGlobalMemory = lstrcpy(lpGlobalMemory, MyString)
'lpGlobalMemory = lstrcpy2(lpGlobalMemory, b(0))
' Unlock the memory.
If GlobalUnlock(hGlobalMemory) <> 0 Then
MsgBox "Could not unlock memory location. Copy aborted."
GoTo OutOfHere2
' Open the Clipboard to copy data to.
MsgBox "Could not open the Clipboard. Copy aborted."
Exit Function
' Clear the Clipboard.
x = EmptyClipboard()
'am 030305_15:16:05 --begin-- **************
'переключаемся на русскую раскладку чтобы не иметь
'проблем с русским текстом в буфере
'(некорректно понимается кодовая страница)
Dim sOldLang As String
sOldLang = switchLang("00000419")
'am 030305_15:16:05 --end-- **************
' Copy the data to the Clipboard.
hClipMemory = SetClipboardData(CF_TEXT, hGlobalMemory)
OutOfHere2:
If CloseClipboard() = 0 Then
MsgBox "Could not close Clipboard."
'am 030305_15:17:26 --begin-- **************
'возвращаем раскладку на место
If Len(sOldLang) > 0 Then _
sOldLang = switchLang(sOldLang)
'am 030305_15:17:26 --end-- **************
Private Function getCurrLang() As String
Dim layoutname As String * KL_NAMELENGTH
Dim z As Long
z = GetKeyboardLayoutName(layoutname)
If z = 0 Then
getCurrLang = ""
getCurrLang = StrZ(layoutname)
'Переключает на указанную sNewLang раскладку - возвращает старую раскладку
'am 030305_15:13:39
Private Function switchLang(sNewLang As String) As String
'"00000419" - русская
'"00000409" - латинская
switchLang = getCurrLang
If StrComp(switchLang, sNewLang) <> 0 Then
LoadKeyboardLayout sNewLang, 1
'v_1.0.0 990630
Public Function StrZ(par As String) As String
Dim nSize As Long, i As Long, Rez As String
nSize = Len(par)
i = InStr(1, par, Chr(0)) - 1
If i > nSize Then i = nSize
If i < 0 Then i = nSize
StrZ = mID(par, 1, i)
End Function | |
to: k@s
(22.04.2012 в 06:02)
| | Мне нужно в буфер и вставлять в форму на сайте
Не до хрена понял. В смысле в аксе скопировать и куда-то вставить на сайт? Ну тогда просто методом копирования делать. А возможно ли это все автоматизировать - ХЗ. Проще наверное как-то в HTML сохранять отчеты или переводить это все. Тут я пас.
В любом случае, если вствляет коды символов и это из-за функции Public Const GHND=&H42 что напоминает некую глобальную константу, сделай через Chy$ авось поможет. | |
to: Гоблин
(21.04.2012 в 16:56)
| | Мне нужно в буфер и вставлять в форму на сайте.может здесь поменять Public Const GHND = &H42.подставить другой параметр.или может есть другой код. | |
to: k@s
(21.04.2012 в 08:24)
| | Хрен знает функцию, не силен в этом, но у меня получилось АЛЕКСАХИНА РУСЛАНА АНТОНОВНА ЧИТИНСКАЯ
Попробуй вставлять из буфера обмена куда вставляешь через функцию Chr$ посимвольно Me.[поле куда вставляешь] & Chr$(буфер или промежуточное поле)
второй вариант - если все происходящее в одной базе и перестановка из одной формы в другую, то присваивай содержимое переменной и потом вставляй. | |
| | Плиз! Подскажите как взять данные из запроса и поместить в буфер обмена.
Нашел как копировать в буфер обмена но русский техт аброказябра ÀËÅÊÑÀÕÈÍÀ ÐÓÑËÀÍÀ ÀÍÒÎÍÎÂÍÀ ×ÈÒÈÍÑÊÀß как это лечится?
Declare Function GlobalUnlock Lib "kernel32" (ByVal hMem As Long) _
As Long
Declare Function GlobalLock Lib "kernel32" (ByVal hMem As Long) _
As Long
Declare Function GlobalAlloc Lib "kernel32" (ByVal wFlags As Long, _
Declare Function CloseClipboard Lib "User32" () As Long
Declare Function OpenClipboard Lib "User32" (ByVal hwnd As Long) _
As Long
Declare Function EmptyClipboard Lib "User32" () As Long
Declare Function SetClipboardData Lib "User32" (ByVal wFormat _
As Long, ByVal hMem As Long) As Long
Function ClipBoardSetData(MyString As String)
Dim hClipMemory As Long, X As Long
GoTo OutOfHere2
Exit Function
X = EmptyClipboard()
OutOfHere2:
Dim strSQL As String
Dim myStr As String
strSQL = "SELECT TOP 10 MyTable.* FROM MyTable"
myStr = CurrentProject.Connection.Execute(strSQL).GetString(adClipString, , , , "")
ClipBoardSetData myStr
End Sub | |
