to: ДрЮня
(15.03.2007 в 15:14)
| | принтер поддерживает 2-ухстороннюю печать- это очно | |
to: Егор
(15.03.2007 в 14:00)
| | двустороннюю не пробовал, а так печатает 2 экз.
docWord.PrintOut , , , , , , , 2
может принтер не той системы? | |
to: ДрЮня
(15.03.2007 в 13:56)
| | хитрый, Хелп я видел, но оно не хо работать | |
to: Егор
(15.03.2007 в 13:39)
| | Prints all or part of the specified document.
expression.PrintOut(Background, Append, Range, OutputFileName, From, To, Item, Copies, Pages, PageType, PrintToFile, Collate, FileName, ActivePrinterMacGX, ManualDuplexPrint, PrintZoomColumn, PrintZoomRow, PrintZoomPaperWidth, PrintZoomPaperHeight)
expression Required. An expression that returns one of the above objects.
Background Optional Variant. Set to True to have the macro continue while Microsoft Word prints the document.
Append Optional Variant. Set to True to append the specified document to the file name specified by the OutputFileName argument. False to overwrite the contents of OutputFileName.
Range Optional Variant. The page range. Can be any WdPrintOutRange constant.
wdPrintAllDocument
wdPrintCurrentPage
wdPrintFromTo
wdPrintRangeOfPages
wdPrintSelection
OutputFileName Optional Variant. If PrintToFile is True, this argument specifies the path and file name of the output file.
From Optional Variant. The starting page number when Range is set to wdPrintFromTo.
To Optional Variant. The ending page number when Range is set to wdPrintFromTo.
Item Optional Variant. The item to be printed. Can be any WdPrintOutItem constant.
wdPrintAutoTextEntries
wdPrintComments
wdPrintDocumentContent
wdPrintKeyAssignments
wdPrintProperties
wdPrintStyles
Copies Optional Variant. The number of copies to be printed.
Pages Optional Variant. The page numbers and page ranges to be printed, separated by commas. For example, "2, 6-10" prints page 2 and pages 6 through 10.
PageType Optional Variant. The type of pages to be printed. Can be any WdPrintOutPages constant.
wdPrintAllPages
wdPrintEvenPagesOnly
wdPrintOddPagesOnly
PrintToFile Optional Variant. True to send printer instructions to a file. Make sure to specify a file name with OutputFileName.
Collate Optional Variant. When printing multiple copies of a document, True to print all pages of the document before printing the next copy.
FileName Optional Variant. The path and file name of the document to be printed. If this argument is omitted, Word prints the active document. (Available only with the Application object.)
ActivePrinterMacGX Optional Variant. This argument is available only in Microsoft Office Macintosh Edition. For additional information about this argument, consult the language reference Help included with Microsoft Office Macintosh Edition.
ManualDuplexPrint Optional Variant. True to print a two-sided document on a printer without a duplex printing kit. If this argument is True, the PrintBackground and PrintReverse properties are ignored. Use the PrintOddPagesInAscendingOrder and PrintEvenPagesInAscendingOrder properties to control the output during manual duplex printing. This argument may not be available to you, depending on the language support (U.S. English, for example) that you’ve selected or installed.
PrintZoomColumn Optional Variant. The number of pages you want Word to fit horizontally on one page. Can be 1, 2, 3, or 4. Use with the PrintZoomRow argument to print multiple pages on a single sheet.
PrintZoomRow Optional Variant. The number of pages you want Word to fit vertically on one page. Can be 1, 2, or 4. Use with the PrintZoomColumn argument to print multiple pages on a single sheet.
PrintZoomPaperWidth Optional Variant. The width to which you want Word to scale printed pages, in twips (20 twips = 1 point; 72 points = 1 inch).
PrintZoomPaperHeight Optional Variant. The height to which you want Word to scale printed pages, in twips (20 twips = 1 point; 72 points = 1 inch). | |
to: Егор
(14.03.2007 в 11:39)
| | Так что, никто не знает, я точно не занаю, помогите | |
to: час
(13.03.2007 в 16:29)
| | Это все понятно, но мне нужно сделать двухстороннюю печать. В Word.application есть команда PrintOUT, но какие параметры нужно указать чтобы произошла нужная печать? | |
to: Егор
(13.03.2007 в 14:01)
| | Может надо код отправки на печать повторить два раза? | |
| | Имеется документ Word, который формируется в Access, как отправить его на двухсторонную печать в 2 экзеплярах (код VBA) | |
